I have a Mk1 with Eibach springs, Koni adjustable schock absorbers, Super Pro bushings and Whiteline ARB.
When I take a highspeed
After testing a little with the adjustable schock absorbers, I took a look under the car and I think I found the reason for the strange behavior.
Please look at the pictures I took after a test drive.
Left side:
Right side:
You can clearly see the ARB is moving sideways and this is in my opinion not normal!
The bushings are the right size and I'm sure the brackets are well thightened.
Do you think this could be caused by to much movement of the sway bar ends?
Should they be mounted the other way?
Everything is
Did any of you have another idea? Similar problem with same setup?
Thanks in advance for the help!
Frank
