This has happened....
Whats the best way to take it off and get a new connector etc?
Thanks,
Will
[Mk2] [Turbo] Gearbox Speed Sensor connector
- IMOC Committee
Re: [Mk2] [Turbo] Gearbox Speed Sensor connector
All toyota electrical plugs are removeable. The ones with more pins tend to have a latch on them somewhere which you can lever out, and then each pin has a small hole next to it which you can stick a flatblade jewellers screwdriver into to release the pin.
The connector will have a 5 digit part number on it as well, if you want a new one. You can also order individual pins with a 10cm tail of wire on as well.
toxo wrote:You can also order individual pins with a 10cm tail of wire on as well.
Just ordered a fe of those for a Supra igniter. £11 EACH!
- IMOC Committee
Peter Gidden - SBITS wrote:toxo wrote:You can also order individual pins with a 10cm tail of wire on as well.
I never said they were cheap
toxo wrote:Peter Gidden - SBITS wrote:toxo wrote:You can also order individual pins with a 10cm tail of wire on as well.
Nor did Toyota when i ordered them.
