i first saw a mr2 turbo some 10years ago, and i wanted one! but my age and lack off money were against me ...... fast forward to 3months ago, and this apeard on my next doors front
after a brief chat with the lass next door i found out it wasnt hers, but i may be for sale soon
A deal was then struck and i am getting her some point this week
to cut a long story short i have since found out the the car hasnt been run for almost a year, needs some work (or replacement) on the passenger sill, battery needs charging, no radio, 151K km's (91K miles if my maths is right) .... and probably lots more, but i cannot wait
Right my plans atm are :-
charge battery
see if it starts <<< anyone know anything i should be aware of before i spin her over?
assess body work
fix stuff
mot
...... fun!
My Mr2 rev2 Turbo
Re: My Mr2 rev2 Turbo
good luck with it the car looks really nice them wheels suit it well too
Be sure to pour some fresh fluids (gasoline, coolant and oil) into her before starting her up.
Congrats on the purchase! Looks like a nice and clean MR2.
Welcome to the fold.
Looks very smart mate!
Hope you got deep pockets
aj.extreme wrote:Hope you got deep pockets
it cannot be worse then my Mg zt 190, i just had its cam belt done .... average cost is around the £700 mark oooh and the crankshaft cambelt pully was u/s , thats £158+ (freelander new part, as the mg/rover part is unavaliable) on its own
Zeiretto wrote:Be sure to pour some fresh fluids (gasoline, coolant and oil) into her before starting her up.
will do
just to refresh my head its 5w40 on the oil and is there anything specific i need to look out for with the coolant?
If well maintained it shouldn't be too bad running costs wise. It's when you get the urge to start tweaking, then you're on one hell of an expensive roller coaster
Magic Beans wrote:If well maintained it shouldn't be too bad running costs wise. It's when you get the urge to start tweaking, then you're on one hell of an expensive roller coaster
well deal has been done, monies changed hands etc ..... battery is charging
i found out some more info too, i has had a new clutch and cambelt (less than 2Kmiles ago) ... and the windscreen wipers dont work but i'll sort that once i have everything else running. upuntil the battery went dead, it was started ever week or 2 for five mins, until 6 months ago, so it might not be as bad as i am expecting.
now the bad bits:-
the interior/roof is or has been leaking (i knew about this)
there is no radio .... just a huge hole lol (i knew about this)
like i said passengers sill has gone
but i'll replace that
Both tyres on passenger side have gone flat (i knew about this)
battery retaing bar (the bit that goes down the side of the battery) is missing
the spare tyre is missing
it needs a good clean
all in all not bad considering what i paid for it
now the bad bits:-
cool
not all bad then
if your interested i have a mint pair of rev 5 cloth seats i removed from my rev 5 to fit leather
not all bad then
ITS ALIVE!!!!!!!
dont know if i have already posted this or not, i have since found out the car has been running within the last 7months, so i gave it a fluid check, charged the battery, and went for it!
fortune favours the brave
so she starts and i can move her now, i have pumped up the tyres and began checking her out
The "not working/problem list"
1) Battery warning light battery voltage =12v (engine off), 11V (engine run @ 2K RPM) alternator looks ok .... but i guess its goosed have chacked all the fuses i can (i cannot find MAIN though)
2) Engine Compartment Cooling Fan Warning Light any ideas on this one? rad fuse ok, but Fan Main relay missing???
3) Cat High Temperature Warning Light no idea on this one, but will check fuses and see if there is one some where
4) boost gauge dosnt apear to work
5) wipers only work in the manual 1 shot, dont work on either timed or slow or fast
Check connections and earths on the alt before replacing for corrosion.
Fan light is for intercooler fan. Check this first. Is it there does it work and is it conected.
Also check the earths under the inlet as can cause electric issues.
sorry alan almost missed this my seats seem to be ok for me atm
Nails wrote:Check connections and earths on the alt before replacing for corrosion.
thanks for the info Nails, i also found this >> http://www.imoc.co.uk/forums/viewtopic.php?t=153276
gunna have a good look in the morning
Welcome sp00n, the car sits nicely on those rims.
Take extra care at this time of year with the 2, especially if this is first one you have driven.
Road_Rebel wrote:Welcome sp00n, the car sits nicely on those rims.
thanks Road Rebel and noted about the weather etc
little update, and i must admit to being a mong, i mistook the a/c for the alternator just been out and had a quick look and the alternator belt is missing .... so my alternator might be ok , just waiting for the new belt to arrive now
Gotta love a red SW!
Thanks guys
today my alternator belt arrived, i got it all fitted etc, went to start her and ....... flat battery (not fully flat but not enough to start her )
while i was in there i noticed this funny green wire
anyone know what its for?
also should there be a relay in the main relay slot in the funk fuse box?
