Hey people a few months ago I broke my heater valve in the funk when I was changing my heater pipes.. So I bypassed the system for now...
Yesterday I put the heater valve in bled everything and all works but it's stuck on the hot (open) position ! When change it to the cold it doesn't move the metal rod in the funk (so stuck open)
Has it siezed because I haven't used the heaters for months ?? Anyone had this problem before I can't be asked to take the dash off
Heater problem
Re: Heater problem
I had my heaters just blowing hot after I put my dash back in, turned out to be a white multi plug was fully mated below the steering wheel on the LHS.
Might be worth a go.
Dan
Dan
Re: Heater problem
danthevanman wrote:I had my heaters just blowing hot after I put my dash back in, turned out to be a white multi plug was fully mated below the steering wheel on the LHS.
Dan
ill have a look cheers buddy
