hi all,
if i was going to do the quad rear light conversion on my rev5 mr2 im thinking of doing it like this http://www.mr2oc.co.uk/know-your-2-know ... bartid=211
if i was to buy a rev1-2 rear light loom could i use the brake light holders from it or would i need a set of rev3+ looms, as i think the plugs should be and work the same am i right ?
If you want to keep your fog lights working, only a few wires won't be enough. I made this mod. It was not a difficult job, but took some time to wire and solder everything.
GreddyMR2 wrote:If you want to keep your fog lights working, only a few wires won't be enough. I made this mod. It was not a difficult job, but took some time to wire and solder everything.
He didn't just use a few wires, he used some diodes too.
yup cheers peter again
in the end i used a pair of stop tail light holders from a 98 celica 4 p600a diodes from maplins and some extra bits of wiring to lengthen everything correctly and after that all wroked perfectly with the help of peter thanks mate
i was a little worried but in the end with a step by step over the phone guide from peter i managed to suss it i also had the wiring diagram in front of me, but i never had to change anything i got it all right first time lol
i now have this
