I need a bit of advise i have got a complete rev 2 turbo gearbox,driveshafts and hubs but just realised that they are non abs hubs-i was going to use it for my v6 but it is a rev3 with abs so is it just a case of finding abs hubs and using the driveshafts or am i completely screwed and need the whole lot?
any help would be greatly appreciated!
p.s i you need any spares just as i have a stoopid amount i am sorting out to sell!
turbo hubs-abs and non abs-help!
Re: turbo hubs-abs and non abs-help!
to retain the abs you will need abs driveshafts and abs hubs/sensors
you could of course just get abs type outer cv joints
Oh bu88er I thought it may be the case!will I still be able to use the gearbox with the different abs shafts?the other option is to remove the abs but don't fancy going down that route!
not sure as most if not all rev3 turbo gearboxes have an lsd so the inner ends are different, i think i have read on here that either
lsd driveshaft fit non lsd gearboxes
or
the other way round
personally id remove the abs as its rubbish anyway, it got better at rev4, my rev3 turbo doesnt have it
or
the other way round
Thanks for the advise!So am i wrong in thinking all turbo gearboxes don't have a lsd then?How do i know if mine has one?
Tbh the abs was always rubbish felt that it kicked in to early
pretty sure only rev3+ have them as standard, not to say rev1/2 might not have them if they were an option.
easiest test is to get both back wheels off the ground (assuming the gearbox is fitted) and spin one of them, if the other side goes the same way then you have an LSD. Im pretty sure that theres other way to check but i cannot remember what it is
jasongtr wrote:easiest test is to get both back wheels off the ground (assuming the gearbox is fitted) and spin one of them, if the other side goes the same way then you have an LSD.
Doesn't work with a viscous LSD.
what type is a rev3 std one then - i dont know
jasongtr wrote:what type is a rev3 std one then - i dont know
Viscous.
mines a rev3 and both wheels spin the same way, what does that mean then?
i must have an LSD as both wheels will leave tyre marks so they both have drive, i though if it didnt have an LSD then only one would leave a tyre mark
well if the turning the wheel test is true?My both wheels turn at the same time when jacked up
- IMOC Committee
You can tell from the transmission code on the stamped plate in the frunk, if you still have the car's original gearbox fitted.
toxo wrote:You can tell from the transmission code on the stamped plate in the frunk, if you still have the car's original gearbox fitted.
I do still have the car!what am I looking for?
- IMOC Committee
On the silver plate in the frunk there's a Transmission line. It will say something like A/TM E153/735.
E153 is the gearbox model. If the last digit of the other 3 numbers (in the example I gave in bold a 5) is a 3 or a 5 then when the car was built it had the stock viscous LSD.
toxo wrote:On the silver plate in the frunk there's a Transmission line. It will say something like A/TM E153/735.
Just checked it and it has the same number as yours:)
so the wheel turning test does work for stock lsd's unless the gearbox/lsd has been changed.
ill check mine later
jasongtr wrote:so the wheel turning test does work for stock lsd's unless the gearbox/lsd has been changed.
No.
- IMOC Committee
Couple that with the fact that the Toyota viscous LSDs are powered by thick goop which becomes less viscous through time/use, and they don't exactly 'lock' when they become less viscous, I wouldn't be that concerned about whether you have one or not!
mine is 753 too, wheels spin in same direction,
does that mean its got an LSD but its not working properly?
- IMOC Committee
It means nothing. As Peter said (twice), you CANNOT do the car in the air, spin the wheels test to determine whether you have a VISCOUS LSD or not. That only works with torsen and plate diffs, not the crappy viscous Toyota ones.
