All MK1 S/c's will run out of puff using the oversize pulley's mainly due to the charge temp being super hot.
This leads to detonation, detected by the knock sensor, which in turn retards the timing.
The ECU also switchs the injectors to 100% duty
(basically full on!) to get as much fuel into the cylinders, and acting to cool the charge.
This results in a loss of power and RICH running.
However.
.IF your fuel pressure is low at high revs, then the engine will run lean and you'll probably blow the HG or worse within a short time, if you're wellying it everywhere.
The SC 4AGZE engines have a lower power peak than the NA 4AGE
(5500rpm S/C compared to 6600 N/A, iirc?), so revving over this will basically not get you any more performance.
To utilise the extra boost, you need mod the mapping, either using a standalone EMS or a piggyback.
Either way, you need to change settings.
To run a DECENT oversize pulley setup you NEED to do the following:
1) improve your intercooling 100%, either a larger IC in a DECENT airflow, or a W2A chargecooler setup.
2) make sure you have a rising-rate FPR fitted AND
(crucially) that it has been set up on a rolling road.
If you feel
"experimental", get hold of a dash mounted fuel pressure gauge.
Try to get an electric one with a sensor rather than one which has the fuel line running into the cabin!
Then watch what happens to fuel pressure at high revs: it should remain at least over 37psi right to the redline
(well.
.5500rpm).
If its less than this, you're gonna have problems.
You could fit an inline fuel pump
, or simply upgrade the stock one
This may have been done already, but it pays to be aware.
Been there.
.done that!
![Wink :wink:](./images/smilies/icon_wink.gif)
