I have finally got my new number plate brackets fabricated and welded on!
Will be buying a 12x6" plate later so will take a few pics of it on in situ just in time for the Silverstone Classic on sunday!
Just simple brackets made from 3mm thick carbon steel, tig welded to the bar. Will have to cut the bumper cover to fit around but should look good once the plate is fitted.
After 7 Months
Re: After 7 Months
There are rules governing the size and position of the number plate, text font etc and I've heard of a few people falling foul of over exuberant traffic wardens and there interpretation of the regulations.
from the DVLA website
The police can issue fixed penalty fines for illegally displayed number plates. Offenders could face a maximum fine of £1,000 and in some cases the number plate may be withdrawn.
Vehicles with illegally displayed number plates may fail the MOT test.
Also, the characters on a number plate need to be a standard height and width.
Your number plate should show the correct:
character height - 79 millimetres
character width - 50 millimetres (except the figure 1 or letter I)
character stroke - 14 millimetres
space between characters - 11 millimetres
space between groups - 33 millimetres
top, bottom and side margins - minimum 11 millimetres
space between vertical lines - 19 millimetres
AFAIK if it possible to display your number plate in the centre of the car then that's where it has to go.
HTH
Alan
HTH
Alan
Re: After 7 Months
Hi Alan thanks for the info.
As I changed my rear lights to Supercharger lights I had to get a 12x6 plate for that as well - it hasn't failed the MOT since they've been on there for the last 2 years.
Unfortunately where my bumper bar has been 're-worked' the holes for the strip underneath have been covered up so I cannot re-attach the plate in the centre.
I did wonder about this when I got the brackets welded on, but I remember seeing a Woodsport car with the plate on the left hand side which wasn't an import and no queries regarding the plate. Sorry Paul, pinched this photo off of your website.
Re: After 7 Months
Should be fine
The alfa's run them offset too, i did for a period as well. Police aremore worried about letter style and shape than number plate size usually
Re: After 7 Months
Cheers Tim
Here is the finished product. Badly need to move the plate up the upper set of holes drilled in the brackets, but did it in a rush.
The eyebrows I wrapped in carbon vinyl look intensely poo but the paint is badly chipped on them so had to cover them in something as didn't have any paint!
