[Mk2] [Turbo] Starting build
stephano
Re: [Mk2] [Turbo] Starting build
Post by stephano »
i tried logging in with my user name and password from imoc and it worked!?
i must have signed up on there years ago :lol:
bobhatton
Post by bobhatton »
Got the welding done on the dry sump tank. Not very neat but it must be 30 years since I last did it.
Its a lot better on the manifold.
Had to cut 3" out of both parts so it will fit in the boot
J-1
Post by J-1 »
Any new updates?
bobhatton
Post by bobhatton »
Still waiting on parts from Jeff in the USA and have got to weld stubs on the inlet manifold to take the nitrous/fuel injectors.
The injectors need to be fitted in the top of the manifold as that is the slowest speed of air flow part and need to be as close as I can get them to the head to try and get the expansion of the nitrous in the cylinders and not displace air in the manifold.
I have to make up the fuel rail first to know what clearance I am going to have.
Also been out racing so that has taken up some time, beating my son with my stock Rev 2 engine last time out, well stock apart from a CT20b on 22 psi boost
:D
bobhatton
Post by bobhatton »
Some more parts have come in.
Magic Beans
Post by Magic Beans »
Any ETA on the parts coming over from the states?
bobhatton
Post by bobhatton »
They will be leaving in the next day or two
GreddyMR2
suspension upgrades
Post by GreddyMR2 »
I'm interested in upgrading my car's handling and wanted to ask what is the benefit of these?
http://i744.photobucket.com/albums/xx83 ... /fser1.jpg
bobhatton
Re: suspension upgrades
Post by bobhatton »
GreddyMR2 wrote:I'm interested in upgrading my car's handling and wanted to ask what is the benefit of these?
This will tell you all about them.
http://www.mr2oc.com/showthread.php?t=434250
You may have to set up a user name and pasword to get to see them but it is a great site
GreddyMR2
Post by GreddyMR2 »
Thank you, I am registered there :thumleft:
bobhatton
Post by bobhatton »
I now have 4 of theses on order, just got to build the manifold and plenum to fit them between the head and bulkhead, its going to be very tight
RyanRs
Post by RyanRs »
Bob, how comes the complex & expensive ignition system? Why not 1zz cop's?
bobhatton
Post by bobhatton »
Just want to use the best, and one coil per cylinder with an MSD system will mean I am never going to get any misfires and will burn any fuel I put in the tank.
calum4492
valves
Post by calum4492 »
what make and size of valves u using bob?
bobhatton
Post by bobhatton »
Ferrea
F1866P E 30 mm 6 mm 99.65 mm 3.5 mm 25º Flo. 1 mm oversize. Super Alloy
F1864P I 34.5 mm 6 mm 100.70 mm 3.5 mm 25º Super Flo. 1 mm oversize
calum4492
bob
Post by calum4492 »
ah same valves as i have jus ordered i take it u got the machine shop 2 take 1mm out of the valve stem area or was it more? i think i will do this as well, no point in changing valves other wise
anymore progress?
bobhatton
Post by bobhatton »
They have taken some off as I think they are made for Rev 1 & 2 shim over buckets, I may need more off so the lock groove to top of valve is the same as Rev 3 valves for shim under buckets.
All the parts from Racerx should be here on Monday, then I can start some trial fitting to see what mods I may need to do to get the dry sump pump drive to miss the chassis etc.
Then it will out with the old engine to get the clutch and flywheel out so I can get everything balanced.
calum4492
bob
Post by calum4492 »
sounds like uv still got alot 2 do
why has jeff taken so long 2 make ur parts? i ordered an inlet from him and got in within a month, granted urs will be alot more complicated but seems 2 be taking ages
bobhatton
Post by bobhatton »
I paid him end of last year, but the dry sump system is his first off and I wanted to change a number of things after he made them so all takes time when he is making manifolds for others also :D
calum4492
bob
Post by calum4492 »
no i know it takes time and hes fantastic at welding so hope all is well wen u get it bob :thumleft:
Return to “Project Cars”
