Hello guys,
I have just finished my speaker set up (for now ) in my car and according to the spec sheets of my amps, speakers and sub, i am pumping through a lot of power so i think its time to start looking for a "better" alternator. (for those audio heads out there, yes, i will be doing the big 3 around the time of change also!)
My question is: Can you buy an uprated / more powerful alternator off the shelf or use one out of another car that will bolt straight on?
Uprated Alternator???
Re: Uprated Alternator???
Road_Rebel wrote:Hello guys,
If you have a NA MR2 then they have a 70amp alternator .... A tubby uses a 90amp alternator they are larger in size but will fit...
Tcb sell 100amp alternators or if you want to hard core you can order a 130amp alternator off the american eBay
But before you buy any check to see if your mr2 uses a Round or Oval plug on the alternator
Thats great information, thank you for your reply!
