[Mk2] [Turbo] turn key and nothing
mr2turbo_rob
Post by mr2turbo_rob »
hi all ive brought a mr2 as a none runner for a project.but stuck on this, as i turn the key nothing happens.all the dash lights come on and all electrics work just cant think of anything else.
rob
mr2turbo_rob
Re: [Mk2] [Turbo] turn key and nothing
no1 got any ideas
tonigmr2
Post by tonigmr2 »
Starter relay is a possibility. Might need cleaning. I used to have a car that did it, quick turn of the key off and on a few times helped to clean the contacts.
mr2turbo_rob
thanks for that i will give that a try
mr2turbo_rob
still no luck :(
alanmr2turbo
Post by alanmr2turbo »
get someone to listen by the starter motor and see if its clicking when yuo turn the key.
Could be the starter moter is jammed if its been stood there a while or even goosed.
I take it you have got a fully charged battery as well?
mr2turbo_rob
battery is fully charged.we have put power to started motor and it spins up.
alanmr2turbo
any info from the previous owner of what happened before it became a non starter?
any immobilser fitted that he never told you about
Can you turn the engine over by hand to see if it isnt seized
mr2turbo_rob
all the old owner said he was driving out of his street and it just died.
not tried to turn it over by hand.how do i do that?
alanmr2turbo
hmmmm dont sound like a seized engine then and wont be anything to do with the starter motor.
Going to be some kind of electrical gremlin. Could be a dodgy corroded earth. There are loads of these.
Gearbox to chassis, frunk battery terminal and under the inlet mainifold are a few of them.
I aint really all that clued up on the electrics side if things though
b16hbg
Post by b16hbg »
You tried bump starting it?
mr2turbo_rob
have tried that but were not getting a spark either
b16hbg
Post by b16hbg »
No spark? Have you got fuel pump going and injector pulse?
Kongaroo
Post by Kongaroo »
Sounds like it could be the igniter? Try swapping in a known working igniter+coil and see if that helps?
Return to “Electrical”
