[Mk2] [Turbo] Will this celica cambelt kit fit my car?
Hi all, i'm back after two years ... I missed owning an mr2. Instead of a 4agze I now have a 3sgte rev1 with 300ish bhp. I have a tight budget at the moment but will this cambelt be ok and will it fit http://www.ebay.co.uk/itm/TOYOTA-CELICA ... 5d2c1de925 Thank Oliver.
Re: [Mk2] [Turbo] Will this celica cambelt kit fit my car?
That is for the 1st generation 3sge and 3sgte. You need one for the 2nd generation 3sgte.
Doh. shame it's cheap. the rev1 turbo is the 2nd 3sgte then?
Most of these kits don't include the hydraulic tensioner you should change this too, for a full change (idler bearing, tensioner bearing, hydraulic tensioner, belt) with decent pattern parts your looking at £150. Anything less and kit is probably incomplete or poor quality.
Yeah I was going to do all of them. I've seen/worked on a few engines where cambelt was supposedly gone when infact it was the tensioner letting go.
Al-sw20 wrote:That is for the 1st generation 3sge and 3sgte. You need one for the 2nd generation 3sgte.
He says he has a rev1?
Yes. They are fitted with the 2nd generation 3sge and 3sgte.
Al-sw20 wrote:Yes. They are fitted with the 2nd generation 3sge and 3sgte.
So what do you call a 1st generation 3sgte?
far as im aware the 1st gen 3sgte is still called a 3sgte but is fitted to a celica.
Fitted to the st165 celica
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
So what year did they start the gen1 3sgte in the st165 then?
I always thought my engine was a gen1/rev1 as its a 1989 3sgte, which I thought was when they were first made?
The st165 is 1986-89
Also the 1st generation 3sgte looks rly different and has a sidefeed intake mani iirc
The ST185 and the tubby came out in 89 no?
greeny wrote:Al-sw20 wrote:Yes. They are fitted with the 2nd generation 3sge and 3sgte.
As already mentioned. The engine in the ST165 Celica GT-Four.
