2mad wrote:It sounds like your thinking along the same lines as me with safer inlet temps being my goal i've hit 50c with my smic.
I ended up getting a st205 chargecooler kit. It was the amount of intercooler pipe work that put me off the bmic as im only running a ct20b.
I picked up a chargecooler, pump, rad, st185 throttle sock and expation tank for around 100 quid on ebay.
Just need a few more bits to install, hopefully all in about 60 quid should cover it.
Again just a thought.
Kev.
I'm going down the st205 cc road as well, but i'm struggling as to where to put my heat exchanger. I don't want to mount it on top of the engine, because that will warm the coolant up significantly, taking away the effect of this system. My other option would be to mount the air filter lower and the core above it or to mount the core in the boot (but i'm not to keen on all the pipework).
What are your ideas on this?
