Have read contradictory info
Do both have an 8 bolt flywheel to crankshaft fastening
SuperRedMR2 wrote:The flywheel on a mk1a is 200, mk1b 212 but on a 4agze its 224mm
You cannot use the n/a clutch on this flywheel
But you can refit the 212 diameter flywheel on the crank and run standard clutch and C52 box
SuperRedMR2 wrote:There are 21 splines on the clutch as well.
What was the clutch and flywheel listed for when you bought it Peter?
SuperRedMR2 wrote:Did you buy these new?
The fidanza flywheel appears to be lighter than that.
Admittedly when I was looking for a lightened flywheel I was struggling to find a 212mm diameter one.All they seemed to throw up was a 200mm flywheel.
I'm thinking that the diameter is in the part number I.E.22100-4AG-200
So I believe you have the 200 mm flywheel
Its not a problem, but didn't you look into the diameter before you bought it?
jon_st205 wrote:Surely it doesn't matter in your case Peter, as long as the flywheel and friction plate mate up and they physically fit in the bell-housing?Just the spline count is the important bit.
Interesting tidbit on the standard flywheels, the 200mm version is heavier than the 212mm.
jon_st205 wrote:I would presume not considering Toyota changed it.![]()
However my guess is that Toda have simply applied the maximum friction surface area possible to their product; it's not like they are going to go to the effort of R&D'ing something which won't stand up to abuse, Toda stuff is aimed at circuit use.
If it measures at 218mm it's a 218mm clutch
(/fly), not a 200
SuperRedMR2 wrote:The Fidanza is 3.7kgs and the Toda is 4.4kgs- are you really going to notice the 0.7kgs?
elbon50 wrote:jon_st205 wrote:I would presume not considering Toyota changed it.![]()
(/fly), not a 200
I agree with everything you're saying there Jon
Looks like I have a really![]()
218mm clutch
Have emailed Toda-Europe with the part number of the fly
They say it"should be the correct part number" for my engine
It was just the part number ending in 200 that made me feel uneasy
cartledge_uk wrote:elbon50 wrote:jon_st205 wrote:I would presume not considering Toyota changed it.![]()
(/fly), not a 200
218mm clutch
The toda is steel not aluminium so will be stronger.
Nice to see your keeping the'std car' as per your regs
