Hi hjs
Welcome to IMOC, yes easy peasy changing the bulb and the glass
(even I can do it and I hate anything like that).
Put headlights in up
/ off position
(remove fuse if you are worried)
Unscrew 4 philips screws 2 top and 2 bottom
Remove chrome surround
Unscrew 3 screws on each side of the light
(black casing) these if your lucky will be held in the right place by a small black rubber band
The casing
(black) can then be jiggled off, will get the hang of it after the first one.
Headlight can then be removed and the bulb replaced but removing the rubber gromit
(make sure you put the gromit and new bulb back on the right way)
If you are replacing the headlight as far as I know its the whole unit, just replace old for new and re fix
(I would say less than 10mins each side easy)
My tip while you are there with the lights out it is also easy-ish to get to the sidelight bulbs, you need small hands but with the headlight out put your hand down the front of the now empty headlight and you can change the sidelights.
Thin plastic gloves help.
The manual says remove the sidelights from the outside with a flat headed screwdriver to change the bulbs, but this very often results in cracked sidelights.
Good luck with it
Rob
