Did you try Carbotech direct for prices?
b16hbg wrote:More expensive than rogue!£200 delivered for the fronts in xp8!
b16hbg wrote:180 from rogue, dont know anywhere cheaper.
Thanks for the advice guys, I'll look into it.Anyone recommend a disc to use with these?
Keri-WMS wrote:It's true that that Wilwood kit will increase your front bias.
However that'sNOT
true of all kits, in fact we designed one version of our kit to work perfectly with the Rev 2 rear brakes
- AND we did a version to work with the Rev 1 rear brakes as well!
Attention to detail when designing a proper upgrade is what makes the difference.There's more info here as mentioned earlier: http://www.imoc.co.uk/forums/viewtopic.php?t=160474
Oh, and you can get Carbotech pads for WMS calipers too.![]()
bobhatton wrote:Keri-WMS wrote:It's true that that Wilwood kit will increase your front bias.
However that'sNOT
Can you make a bell and rotor for standard calipers?
bobhatton wrote:Ok, so what comes with your kits, can you put some photos of the disks up please
minky350 wrote:Hi Keri-WMS.I dropped you an email last week but I didn't receive a reply.
Could you let me know costs and availability for a rev3 turbo front brake kit?
