Kind of mr2 related
SuperRedMR2
Kind of mr2 related
Post by SuperRedMR2 »
Right,
Problem is:-
How do I get a 4AGE engine c/w gearbox onto the back of a half truck transit, flat bed is 1.2m above the ground without the use of an engine hoist/crane?
Getting it off may be easier, but getting it on you cant use gravity as its so bloody heavy!
Any ideas?
User avatar
Lauren
Re: Kind of mr2 related
Post by Lauren »
Have you got any friends?
SuperRedMR2
Yes, the one who's house its at.
We're not weak, but we also have to work the next day and don't want a horrific back problem.
Getting some sort of ramp made at work shouldn't be an issue but my brain is currently mashed and can't think of anything.
loudandproud205
IMOC Organiser
Post by loudandproud205 »
Any body you know with a boat winch?
Strap it in the back of the Transit pull it up the ramp.
Got boost?
Kinda!!!
0.3 bar FTL
stenky
Post by stenky »
or winch it up the ramp using some decent ratchet straps :)
Peter Gidden
Post by Peter Gidden »
Split the engine and gearbox :idea:
boondougal
Post by boondougal »
Defo split it, should be very liftable then!
elbon50
Post by elbon50 »
Could the buyer bring a mate along Alex :?:
That'd make four of you to lift :)
SuperRedMR2
Peter, I did suggest to the buyer about coming to my mate's in Clacton and picking it up but he wanted to knock me for £15 worth of diesel.
The box will be split and therefore I should be able to pick the lump up myself.
tonigmr2
Post by tonigmr2 »
two very long planks of wood, tie it to them, lift from the ends.
Works every time.
SuperRedMR2
Carbon Parts
Wrong thread ](*,)
pk_090
Post by pk_090 »
Im looking at making these for my car!
Alex
charged wrote:Mine's probably screaming 'stop raping me' :D
malwhiterev3
Post by malwhiterev3 »
be easier inversting in a winch but should be easy enough to lift if there are 2 and you split it
