Right after a long wait i finally have my retracting mirrors installed.. the only problem is the drivers side doesn't retract.
If you press the button the passengers side retracts but the drivers doesn't if you then press the button to fold the mirrors in and push the drivers one in and press the button both wing mirrors open as they should..
Any one else had this issue? Is it the relay that has an issue?
If it opens then it is getting a signal from the relay. Check the wiring to the relay and also inspect the assembly on the mirror motor. It could be that the cogs have been installed incorrectly and are not moving freely in one direction.
I am assuming you guys did the UK mod to retain the heated mirrors and not the full loom install.
John.
Torero wrote:If it opens then it is getting a signal from the relay. Check the wiring to the relay and also inspect the assembly on the mirror motor. It could be that the cogs have been installed incorrectly and are not moving freely in one direction.
John.
No i have the full loom mirror install. basically doors and mirrors from a GT..
Draven wrote:No i have the full loom mirror install. basically doors and mirrors from a GT..
Worth trying the relay then, you could also swap the mirrors over and try them on opposite sides to see if the issue is local to a single unit or common to either mirror. It should narrow down your options.
Yep i'm going to buy another relay and see if that helps.. would be such a shame after waiting months to get the retracting mirrors for them to not work.
Shouldn't be the relay as the whole assembly worked on my car before I sent them to you
Does sound very weird though....... I can't think of any reason off the top of my head why one of them would suddenly stop.... Is everything definitely connected right?
bluesmoke wrote:Shouldn't be the relay as the whole assembly worked on my car before I sent them to you
Well i'm going to quickly take off the door cards and un plug everything and plug it all back in again it may just be a dodgy connection on the drivers side..
oteck wrote:do a continuity test on the driver side to ensure the wire is solid. the door harness is prone to sheering from all that opening and closing and water
