[Mk2] [Generic] Bilsteins
TRINDA1664
Post by TRINDA1664 »
Hello
Has any one got any tips on how to service bilstein struts? E.g spray WD40 on the rod and work it up and down?
Also are the bilsteins struts rebuild able?
Dan
ToyotaTosh
Re: [Mk2] [Generic] Bilsteins
Post by ToyotaTosh »
Hi Dan, I've been looking on this suject for a few months, and it appears that the bilsteins are not rebuildable as they are sealed.
Try to find replacements, but new ones are expensive !
Hez
Post by Hez »
Bilsteins are not rebuildable unfortunately, and as said they are not cheap expect £120-150 a corner for the standard black bilsteins and 160-180 a corner for the yellow bilsteins, failing that get rebuildable struts and drop uprated inserts into them but they not cheap either!
Peter Gidden
Post by Peter Gidden »
Koni adjustable SSK. Work well, and guaranteed for life. About £500.
2tmike
Bilsteins
Post by 2tmike »
Hi, What problem are you needing to solve by 'servicing' ?
TRINDA1664
All it is I have brought some second hand bilstein and want to give them a quick oil/service before they go on the car. But if there is nothing that can be done that is fine.
oteck
Post by oteck »
you'll have to send it back to bilstien for a rebuild and revalved to your spec.
Nic
Post by Nic »
Chris Wilson can rebuild and custom valve Bilstein dampers, contact details HERE
ToyotaTosh
unable to view that mate
Nic
Post by Nic »
Chris Wilson
Race and performance road car servicing and preparation in north Shropshire. Race and road car engine building and tuning. Suspension development and geometry specialist, all Supra work and other cars too! Latest Bosch KTS and Vagcom diagnostics for all cars. 07971-952084 [email protected]
