1995 Turbo Rev 3 running approx 300bhp
88k Miles
TD05 Turbo
Catcams
Tein Springs
HKS Hardpipe kit
Blue flame Exhaust
TRD Steering wheel, and gear knob
Belts change 5k ago
Clean interior and exterior no rust
TIA
psummers wrote:Is this the car you are looking at?
djpkins wrote:without a mappable ecu, bigger fuel pump and injectors..
.the turbo mayaswell be standard.
.the cams will make it laggy.
.there is alot of money to be spent on it to make it what you think it is.
.walk away, it's half a job.
.isn't the td05/6 a dinosaur now?
.also, the clutch may be ok with the
"300bhp" it's making now.
.which it prob isn't unless you have a dyno printout to prove it and I would say it's certainly not a safe 300fwbhp without a mapped ECU.
.but when you step it up a bit, you'll need another
£5,6,7,8+ for a clutch that'll hold it all down, depending on how much you let out.
Not at all trying to put your flame out,,,,but you asked for an opinion![]()
and thats what I think on face value.
.you havn't really submitted all that much info or any pics so I'm basing my judgement on what I would pay for it on fleabay as a chancer.
psummers wrote:See if you can track down the previous owner or the guy who rebuilt the engine.They may shed some light on what djpkins said.
Personally I'd have a good poke around those extended arches, just to check it's all been fitted properly.
At the end of the day just take it for a test drive and see if you get on with it.Granted it does seem to have a fairly weird spec
(uprated turbo and cams but no boost controller or mappable ECU fitted) so it does seem a bit half done.
If you can get hold of the guy who rebuilt the engine then he may know more.
It also looks to have the stock intercooler as well, they are useless and would need replacing straight away.
I'd say to get it to 300hp you would need new ECU, intercooler and electronic boost controller(may be one included with the sale), Easily another
£500 at least.
If it's in good nick and you get it for
£2400 I'd say you've done well.
Rob B wrote:That cars on here or mr2oc so have a sniff for more info.
If its clean and in decent order its a fair asking price imo(allowing for haggling)
The colour scheme wont be to everyones taste though
