RedMR² wrote:Re-feed the inner brake lights with your fog light feed.Job done
Peter Gidden - SBITS wrote:Sort of..
The inner bulb will be a 21W single filament bulb.![]()
It is quite possible to connect them to a switch, and hey presto, fog lights.
However, it is posiible the MOT tester may get arsey since the outer lights both on(21W and 5W) may appear brighter than the inners.
And the fog is supposed to be the brightest.
The way we connect them,(which is not the only way, just one way), is to get two more twin filament bulb holders for the inners.
Wire up so you have 4 side lights and 4 brake lights.![]()
Then intercept the inners with relays or diodes so the fog light switch illuminates the 21W and 5W filaments of the inners.![]()
Then the outers can't be brighter than the inners!
RedMR² wrote:]My best one so far was to wire them 4 tail lights, outers as brakes, inners as fogs.
Peter Gidden - SBITS wrote:RedMR² wrote:]My best one so far was to wire them 4 tail lights, outers as brakes, inners as fogs.
Did you do it, or did I?![]()
loudandproud205 wrote:I changed my reversing light in to a fog light
I asked God for a bike, but I know God doesn't work that way.So I stole a bike and asked for forgiveness.
RedMR² wrote:loudandproud205 wrote:I changed my reversing light in to a fog light
Got mine like that at the moment.Every time I go to Peter's he tells me I've a reverse light out
loudandproud205 wrote:.
.other than my MOT its the only time I use the fog light
