loudandproud205 wrote:Did you get in it?
Because if it is the catch then you may have a bit more trouble
GOT IN
( I have only just bought the car, by the way
Was not the cable or faulty catch.
It was lack of maintenence of the catch.![](./images/smilies/spacer.gif)
A good pull on the interior release leaver, thinking, if the catch breaks, I
am in no worse a possition, and the bonnet opened.
So clean where you can, and OIL the moving parts of the catch, bits that
slide over others, pivots, and special attention to the cleanness,
smoothness and oilyness of the U shape rod on bonnet, and the catch
bit that holds it, then they will all slide effortlessly in future.
i also, and will have to check this in the future, gave the two round rubber
stops each side of the bonnet, in the bonnet at the front, one eighth of a turn
( screw inwards
) just so there would be less pressure pushing up the
bonnet when closed.
As said, will check the correct height for easy release in the future.
Thank for all your replies, and for a private message received that should
not be made public, for openng the bonnet by other means.
thanks again.
R.a.M.
