There are many, many considerations to take into account, so take the sweeping generalities about 16" rims with a pinch of salt.
Unless you start getting into expensive custom made wheels then the odds of you finding the perfect diameter, width and offset are slim.
Finding the perfect tyre size to match is even harder.
Everything will be a compromise.
On my Roadster I currently run 16x8 at the front and 17x9 at the rear.
Offsets have to be made up with substantial bolt on spacers at both ends of the car and I've converted to a 5x114.3 stud pattern at the rear
- partly to improve the selection of wheels available.
Since we've installed the supercharger, both the brakes and tyres need upgrading.
We need to go six pot at the front and four pot at the rear.
The braking force of the car is adequate at the moment, but the longevity of the pads is not
- they need to be replaced every five hours or so.
This will necessitate larger diameter wheels at the front so we'll bump up to 17" and almost certainly increase the diameter of the rears to 18".
The upshot
(for us) is that this in turn improves the selection of tyres available, and probably eases the wheel offset situation as well
- it all needs careful consideration.
So my advice would be to start with the things you can't change
- such as the minimum diameter required to clear your brakes
- and then work out what tyres you want to run.
Then see if you can get rims to suit.
If you can't, revisit the tyre situation and see what the nearest options are.
It's a convoluted process and you won't know if your choices are right until you've made them.
