Removing Sound Deadening Material
elbon50
Post by elbon50 »
Want to remove the bitumen material from the floor & rear firewall
Have had a go with hammer & bolster chisel
Looks like a long slow process
Whats the best way to tackle that please ?
Peter
kaiowas
Re: Removing Sound Deadening Material
Post by kaiowas »
Wait until winter and do it on really cold morning.
User avatar
Lauren
Post by Lauren »
What Phil said. I did mine in winter. Needs to be freezing ideally, then you can just whack it with a hammer and it will just shatter. Might be an idea to wear goggles!
elbon50
Post by elbon50 »
kaiowas wrote:Wait until winter and do it on really cold morning.
Ahhhh yes, it goes brittle & breaks off easier ?
Peter
pk_090
Post by pk_090 »
did ours in the snow last year just smacked it with a hammer and then vacuum cleanered'd it up.
Ive always wanted to try doing it with a CO2 fire extinguisher i know they are cold but i cant get my hands on one.
You can also buy "freeze spray" peter comes in can format and does exactly what it says on the tin. Mainly used in the composites world when using pre-preg as it has to be stored in a freezer and starts to cure when out so the freeze spray can buy you a couple more mins.
http://www.ebay.co.uk/itm/Rothenberger- ... 1474wt_982
elbon50
Post by elbon50 »
I have a can of freeze spray
Will have a try with it
Peter
tonigmr2
Post by tonigmr2 »
I was told pipe freeze spray, but tbh even on days of normal temperature I didn't have that much trouble, it was just hitting it right.
cartledge_uk
Post by cartledge_uk »
As toni says, any day is fairly easy. You can also go the other way and use a heat gun and you can scrape it off like sunpat. I just hammer and chisel
jon_st205
Post by jon_st205 »
Did mine with liquid nitrogen 8)
MartG
Post by MartG »
I did my first one using the 'cold day, hammer & chisel' method, and the second with the 'heat gun & scraper' method - the second was much easier and quicker, as well as being nice and warm :thumleft:
pk_090
Post by pk_090 »
jon_st205 wrote:Did mine with liquid nitrogen 8)
any left? :)
elbon50
Post by elbon50 »
Tried the pipe freeze method
Works fine but looks like I would need quite a few cans of freezer
Can only do a small area at a time
Peter
cogboy
Post by cogboy »
I'd recommend finding an engineering graduate with a degree, but no job, and leaving him inside the car for a couple of days with a heat gun, a spatula, and a crate of beer.
-From experience.
pk_090
Post by pk_090 »
I d recomend freezing over heating of the sound deadening every time. First time we did it on a cyborg 10 of us using blow torches and gasket scrapers didn't end well took us ages to do, very messy and some of the fumes that came off made us all sick the next day!. Since then every other car we have done we have frozen and chipped it off then hoovered it up with a vacuum cleaner afterwards. CO2 fire extinguishers, liquid nitrogen or dry ice (solid CO2) all work well if you can get hold of it, freeze spray although little cans and takes a few works well. Failing that wait for the snow this year that is when we did the 2 BMW's!
Alex
elbon50
Post by elbon50 »
pk_090 wrote:I d recomend freezing over heating of the sound deadening every time. First time we did it on a cyborg 10 of us using blow torches and gasket scrapers didn't end well took us ages to do, very messy and some of the fumes that came off made us all sick the next day!. Since then every other car we have done we have frozen and chipped it off then hoovered it up with a vacuum cleaner afterwards. CO2 fire extinguishers, liquid nitrogen or dry ice (solid CO2) all work well if you can get hold of it, freeze spray although little cans and takes a few works well. Failing that wait for the snow this year that is when we did the 2 BMW's!
Alex
I agree Alex. Have done a bit with a heat gun & also tried a freeze can. Much prefer the freeze method but a little can doesn't go far
So will wait for the cold weather now I think
Have heard that another long cold Winter is forecast. So if that's the case there should be plenty of opportunity
Peter
pk_090
Post by pk_090 »
i think im going to wait and do mine then. Is it just on the bulkhead behing the seats where theres sound deadening?
elbon50
Post by elbon50 »
pk_090 wrote:i think im going to wait and do mine then. Is it just on the bulkhead behing the seats where theres sound deadening?
No it's all across the floor as well and up the sides of the central tunnel Alex
Quite a bit of weight altogether I think
Peter
User avatar
Lauren
Post by Lauren »
It's not a huge amount of weight Peter. Think I weighed mine at 8kg.
If you look at that comparitive to the weight of the car it's less than 1%.
Jim-SR
Post by Jim-SR »
I found it closer to 15kg, and that ~1.5% weight saving is significant enough when its costing you £0 and just a days worth of effort. You can't get a return like that anywhere else without spending significant money.
elbon50
Post by elbon50 »
Lauren wrote:It's not a huge amount of weight Peter. Think I weighed mine at 8kg.
Very true Lauren but it helps to chip away at the total weight
Will take out the weights under the seats & look for lightweight seats
Bumper bars (front one is already out - rotten)
Stiffening from under bonnet, rear bootlid & engine cover
Errmm ...running out of ideas already :)
Peter
