Its had new topmounts
New fibre washer under topmount
Droplinks
Lower balljoints
different steering rack
different steering column
Anyway have done all that and have always had this anoying rattle over bumps,over 30 you can't here it but at all others times you can.
Anyway the cure.
OSF was well worn and the nsf was ok but replaced them both,however nsf does make a noise over heavy bumps but I think the insert has gone so will replace with 2 new complete units when I have some cash
Will post pics when I get it to work,hope this helps anyone with same rattle.
![Image](http://i69.photobucket.com/albums/i53/Toecutter_xjr/Picture008.jpg)
![Image](http://i69.photobucket.com/albums/i53/Toecutter_xjr/Picture007.jpg)
![Image](http://i69.photobucket.com/albums/i53/Toecutter_xjr/Picture006.jpg)
You can see from the pics how the central hole and slot has worn causing movment on the damper shaft
