My mate is selling his tubby as he has now got an integra type R . He has spent a fortune on this car as you can see in the ad i told him to keep it but he wouldnt listen. His loss will be someone elses gain.
Here is my much loved MR2 Turbo Rev2, I am selling it due to the fact that i now have three performance cars, so one has to go to make room for my project!
I can prove with the last MOT that it has only done 14miles, so it should laugh at the next MOT
Professional work carried out on the car in the last year (receipts to prove)
Engine rebuild ( I have many pictures of the work I can supply)
Uprated metal head gasket, Inlet and exhaust gasket throttle gasket (Genuine Toyota)
Turbo charger Rebuilt and uprated to metal shafted impeller (Balanced and tested certificated by TURBOTECHNICS)
Uprated GAB Coil over suspension
New Cambelt
New Magnecore leads
New K&N Air filter
New Alternator
New Battery
New tires
New Stainless steel down pipe (De-cat and passes MOT due to import)
New brake callipers
New ball joint
New OEM clutch
New Clutch master cylinder
New gear stick and handbrake gaiters
I will get some pics up later
[FINALIZED] Rev 2 MR2 Turbo Tbar black
Re: [FINALIZED] Rev 2 MR2 Turbo Tbar black
Right he has just put a new MOT on it and is looking for £1600 which considering what he has spent on it is a bargain. Either bid through Ebay new item no is 320735338494 or contact me and I will give you his tel no.
Hi
Can I have your mates Name and number please?
Cheers,
Dave
Cheers,
Dave
