so today I thought I had better introduce it to the bits that have adorned all my MK1s
Erm.
![Wink :wink:](./images/smilies/icon_wink.gif)
![Image](http://i98.photobucket.com/albums/l256/supercharger_1963/momopedals001.jpg)
gen.
![Image](http://i98.photobucket.com/albums/l256/supercharger_1963/momopedals002.jpg)
more tinkering to follow as my 20V 4 branch manifold has arrived from that US of A
![Dancing \:D/](./images/smilies/eusa_dance.gif)
elbon50 wrote:Do you get correct horn function& indicator cancellation with that S/Wheel boss
Kevin
Could you post pics of the 20V manifold as it is now and the mods you have to make to get it usableon the 16V engine please
Peter
elbon50 wrote:Is 20V manifold different at bottom end to the N/A/S/C type
How will you connect to your exhaust system
Peter
bobbyh wrote:what's the advantage of the 20v? bigger bore I assume?
IanClements wrote:Would be interested to see how that goes Kev, any cheap way of getting more power sounds good in my books.Let us all know how it drives after you fit it.
Lauren wrote:It ought to give it a bit of a boost.Mind you the runners are fairly short which might limit the benefits.
But it will make more noise, in a good way.
kevin..in wrote:Lauren wrote:It ought to give it a bit of a boost.Mind you the runners are fairly short which might limit the benefits.
pretty much what I said then Lauren
SuperRedMR2 wrote:It looks a different shape to me![]()
PW@Woodsport wrote:Kev i don't know what manifold that is but it's not a 20v.On a 20v manifold the outer holes are close to the original 16v holes, so close there is a half hole overlap, your outer holes are miles away.
Looks dead easy for you to modify though and won't be any problem, just thought i'd mention it doesn't look like a 20v.Also the lower flange looks very different to a 16v, again shouldn't be a problem.
kevin..in wrote:
Perhaps Lauren will jump in with the link to that place in Macc.that does custom exhausts, maybe if i post something like
"for sale"
"lotus twin cam" or
"track day" I know what will do it
"blue interior"
