are these the right ones i need
Exhaust manifold gasket
Water by pass gasket
Gasket turbine outlet elbow
GASKET, TURBO OIL INLET
GASKET, JOINT
Exhaust manifold to turbo gasket
djpkins wrote:I thought their was also an issue with the heat shield from ct26 not fitting a ct20 but mine fits fine with all 3 holes lined up.
jimGTS wrote:This a refurbed Mr2 ct20b(just says Toyota on the housing), or have you gone and bought a ct20 diesel turbo
(useless)?
