I'm looking at having a front TRD anti roll bar collected by courier, anyone got an anti roll bar lying around they can weigh so I can estimate?
Doesn't matter if it's stock, TRD or any other aftermarket, if i've got something to work from I can estimate near enough.
Anti roll bar weight?
Re: Anti roll bar weight?
ill weigh one this evening for you if i remember
Why dont you just stick the one you have on the bathroom scales??
The back standard 18mm one weighs about 5kg so I would imagine the front would be about the same
Phew. I wondered at the Subject, I thought you were taking it off to save weight
Cheers I'll stick 7kg in which should cover it... last time I underestimated size/weight for an international DHL shipment I got whacked with £50 extra charges when the shipment with the correct weight would have only cost about £8 more
