If anyone has a REAL Gen III wiring diagram I would love to get a copy, as all the copies I have are from the Gen II.
I downloaded the set of electrical wiring diagrams ages ago,
Mat
BrianUK wrote:I do have two questions however:
I understand the ST205 Chargecooler pump is rated at 12 amps- and can pull up tp 18 amps
(ref: http://celicas.messageboard.nl/viewtopic.php?t=306)
- one reason it doesn't run continuously on the Celica.
If thats the case would it not be better to rig it so that it only pumps when boosting?
BrianUK wrote:Im think of using a Radiator fan fixing kit
http://www.jperformance.co.uk/universal ... ufhkgmrch1
to fix my rad to the existing rads- but put a spacer in between them.
This should be easier to fit
- and not rust lol!
- any comments?
- Brian
hmltnangel wrote:Dragging up old thread time
A few questions about this as'm almost done fitting mines.
1.Is it necessary to have the old IC fan still running? Or can I do without?
2.Anyone get a good final solution to the swirl pot? The setup I got doesnt have one, I'm guessing any expansion tank would be ok as long as its small?
3.I'm using a Rev3 MR2 ECU.
Whats the best way of wiring up the pump along with a warning light if the pump fails?
4.Wahst the easiest way to wire up a light of the level falls?
cheerss
