[Mk2] [NA] How big a deal to change steering wheel?
brgbrm
Post by brgbrm »
I miss the momo I had on my v6, is it a big job to switch from the standard steering wheel on an NA?
HighwayStar
Re: [Mk2] [NA] How big a deal to change steering wheel?
Post by HighwayStar »
Does it have an airbag? If not pretty simple I think.
R.
Jez@Devoted
Post by Jez@Devoted »
if no airbag, 5 min job
cvega666
Post by cvega666 »
undo 1 screw from the bottom of the wheel, pull the horn surround off, get a 19mm socket and loosen the bolt (without taking off), wiggle the wheel free, undo the bolt completely, removed :)
brgbrm
Post by brgbrm »
I just looked at the face of the steering wheel and it doesn't say airbag on it so I assume it doesn't (it's a rev3 uk car).
So, that's great, thanks! I just need a momo now, or are there other decent steering wheel types?
SonicSW20
Post by SonicSW20 »
Momo <3
Some of the OMP wheels look pretty smart - depends on what style you want though I guess.
HighwayStar
Check my garage for a shot of a quite small and slightly flat bottomed Sparco.... looks quite oem in my opinion. :thumleft:
Harold
Post by Harold »
I have a sparco wheel that's pretty nice, you could look into those.
brgbrm
Post by brgbrm »
Thanks for those thoughts. Anyone any idea what the minimum sensible diameter is?
SonicSW20
Post by SonicSW20 »
Mine came on the car when I bought it - its either a 260mm or 280mm and its a bit on the small side - quite nice when you are used to it though.
Razor04
Post by Razor04 »
350mm is optimum size any smaller and its like you're driving with a shirt button :lol: oh and you wont be able to see all of the dials through the wheel either at less than 320mm
SonicSW20
Post by SonicSW20 »
Yeah.... my temp and fuel gauge is somewhat obscured :lol:
