Any pictures of the curb mark? If its a standard Alloy wheel
(Not polished lip) then we just use filler but if its a Polished lip we use a wheel machine, looks a little bit like the machines that change tyres
![Image](http://www.alloywheelrepairs.net/Content/Images/Tyre%20Change/AWR-210505%20005.gif)
But with a Polisher
/ grinder arm instead.
You put the wheel on
(take it apart if its a split rim), lock it on, press the pedal to spin it and then grind it down till the marks gone.
Because the wheel is spinning the whole lip stays even.
Once marks are gone you spin the wheel again and by hand hold 180 on it, 320, 400, 500, 800, 1500 and 2000.
Then change the grinding disc for a polishing disc and put metal polish on and polish it up.
The longer you hold the 800, 1500, 2000 on it the better the finish.
Obviously if theres a huge curb mark you might not be able to get it fully out
No idea how I would paint them spokes sorry, Im just starting to do wheels realy
but at a guess what I would do at the bodyshop I work at is take wheel apart, mask the areas of the spokes off you dont want painted to protect them from the sanding disc then 400 the inside of the spokes.
take masking tape off, de grease them, mask up again and then paint them how I said before.
but thats just a guess
Stopped back tonight to finish prepping my stock wheels.
Rear ones will come out good but the front might not be as good.
looks like someone has shot
/ sand blasted them at some point making them all bitty.
Going to paint them in a Mirror black
(VERY shinny black) and might dust some silver on them or a light coat of white, wonder what that would be like.
Oh yea, NEVER get your wheels sandblasted thinking it will save you stripping
/ sanding them down.
it chips the wheels to bits.
