In need of replacing my sump pan as its corroding. Any1 know where i can buy one other than toyota which will prob be expensive??
rev2 na
Help! Need a New sump pan, But Where?
Re: Help! Need a New sump pan, But Where?
Second hand? I've got a rev3 NA sump you can have for a small donation...
EDIT: Thinking about it I should probably place for sale ad's for the two parts of the sump first, and then separate ad's for each of the bolts as well
Cheers pal but ideally new unless there mega bucks. Forgot to say its a rev2 na. will a rev3 fit? I'll pm you if i can't source one. Ta
Sorry- rev 2 is different mate
- IMOC Committee
Think they are about a ton from Toyota.
Thats not too bad i'll call in this week. Is there anywhere else that will do them?
Replaced mine on my Rev3 n/a at the sum of £150 from mr T
clubae111.com
Red Rev2
Black Rev3
Red Rev2
Black Rev3
You could pick up a whole second hand rev3 NA engine for that much!!
Have you tried TCB?
Have you tried TCB?
think i'll have a look round the scrappers to get the best condition 1 i can. its a good point for the cost of a sump pan i could get a new engine!
