Hi Guys ![](./images/smilies/spacer.gif)
**I have edited the title of the thread as it is now going a whole lot deeper.
so I think I need to add some context.
The car in question is a 92 rev2 tubby with a ct20b turbo.
The engine was reconditioned in 2008.
The car itself has had a colourful past, having been owned by RED TYSON, welshboyo and DBIAGIONI whom I bought it from yesterday.
Dave brought the car back from the brink of the breakers yard to where it is now.
So im taking the baton to restore the full potential back into the old girl! Inevitably there are issues, that need to be overcome to get her there, which is why I have started this thread and now modified it slightly so I can keep all technical issues with this one in one place.
It will also be nice to chart the progress as i have some pretty cool plans further down the line.![](./images/smilies/spacer.gif)
Anyway heres a piccy
(from the ad)
not to everybodys taste, but the body work is pretty mint, no rust or chips.![](./images/smilies/spacer.gif)
![Image](http://i845.photobucket.com/albums/ab12/GTSAARON/KGrHqNlcE2DdFqBNoisWwmD_3.jpg)
So the project starts.
as per usual with a list of problems.
lol first of which I asked below:
Looking for your thoughts on the following problem;
Collected Rev 2 tubby today, running ct20b turbo and metal HG with AVCR fitted but not programmed properly yet, so boost spikes above set value of 1 bar.
It has a FCD fitted, but im not sure if its working.
was driving along, accelerated and hit perhaps slightly over a bar with boost spike and the car jolted, and engine light illuminated momentarily
(I think it hit fuel cut) and then would not let me use any boost at al, until I reset the ECU.
Checked fault codes.
34.
boost pressure, so, could it be that
1.
the boost spike exceeded the raised fuel cut level set by the fuel cut defender, or
2.
could it be that the fuel cut defender is faulty, or
3.
lastly could the knock sensor have failed due to the overboost?
The chap I brought the car from is fantastic, really helpful and tried some remote control diagnosis over the phone, and has even bought a new knock sensor and is posting it to me incase thats the problem.
My first port of call tomorrow is to set the Apexi AVCR up properly and see it this stops it, then unplug the factory plug thingy near the diagnostics port that controls the fuel cut, and this should eliminate possibilities and show the true cause.
so anybody any ideas that may save some head scratching in the mean time??
Aaron
