[Mk2] [Turbo] a/c gas
i am looking to re gas my a/c system does any one know what type of gas would be orignaly fitted asif i use the most upto date gas it can effect the seals if it has the old style gas?
Re: [Mk2] [Turbo] a/c gas
rev2 is old gas r12 i think
rev 3 on is newer gas r14
it usually have a sticker on the raintray
or take it to kwikfit , they check it from you free i believe the connector is different on older gas
Mine is also a rev2 aka 92 and I've thought about getting it regassed but was aware that the stuff had been banned,however
Ive heard RS24 can be used as direct replacement, and is CFC ok, anyone tried it
http://www.bee-cool-aircon.co.uk/questions.html
My car is an import, or was made before 1994, and has R12 refrigerant. Can this be re-gassed, or retrofitted?
We are also able to Retro-fit older vehicles carrying the now banned R12 refrigerant. This was fitted to vehicles prior to 1994. We can use an industry accepted replacement gas called RS24. This gas, although expensive, will avoid the need to replace all the major mechanical components of the system, and will prove to be almost identical to the now banned R12
Also found this http://www.subzeroac.co.uk/
might ask around for this stuff instead. at least this could be used to test my system to see if it works (I can hope)
Hope this helps Paul
Rota torque drifts Japseed exhaust Apexi air filter Gizzmo ibc Apex springs Hks turbo timer 242bhp at .8 bar
