I have heard that na and turbo bottom ends are the same, can anyone confirm? I need to replace mine as on inspection its well beyond a crank regrind.
Its a rev3 bottom end in a rev2 car.
Cheers in advance.
[Mk2] [Turbo] Bottom end dead, what blocks can be used?
Re: [Mk2] [Turbo] Bottom end dead, what blocks can be used?
Crank is the same, block and pistons are different.
Thanks mate, does that mean the cranks are the same rev2 rev3 etc?
