Can i just cut the Aircon belt off?
mr2turbo99
Post by mr2turbo99 »
As above :thumleft:
Steve Horrocks
Re: Can i just cut the Aircon belt off?
Post by Steve Horrocks »
Depends on what you're doing? If it's no good to you, yeah, but if you're refitting a new one, may as well release tensioner as you'll have to anyway to fit new one.
Last edited by Steve Horrocks on Thu Apr 28, 2011 12:01 pm, edited 1 time in total.
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
JDM-MAT
Post by JDM-MAT »
Yep, and I agree with the above.
mr2turbo99
Thanks guys, yup its no use, aircon packed up a long time ago.
JDM-MAT
Post by JDM-MAT »
Think mine has gone the same way so I will be cutting mine off
Charged
Post by Charged »
You might as well lose the gubbins as well and shed some weight you fat mk2 barstewards!
JDM-MAT
Post by JDM-MAT »
Harsh :mrgreen:
N9THX
Post by N9THX »
I've had the aircon compressor chopped out the last engine swap. How much would that have weighed?
Is there much weight loss in removing the pipes etc?
Is there a radiator for the aircon that can be removed?
Sorry for the thread jack but it's all related.
meggs88
Post by meggs88 »
If any of you guys are getting rid of your air con pipes, then I may be looking for a set, as long as the are useable and from a rev3 onwards?
Nails
Post by Nails »
n9thx wrote:I've had the aircon compressor chopped out the last engine swap. How much would that have weighed?
I removed it all of my first mr2 turbo as it didn't work. Compressor is quite weighty. Probs more then 10 kilos? The aircon rad is in front of the nornal rad and is quite light but also easy to remove. Metal pipes under the car be a about 1 kilo-ish.
