[Mk2] [Turbo] passenger foot well
ok its been a while since i was on here but with the good weather i recon its time to do the re-shell problem is i have forgot where 1 or 2 things go got most sorted but there is 1 plug left over from the harness that come's in from the frunk its a square-ish/rectangle shape with at least 20 pins in.
.I am not sure but i think it might go into a relay box or small ecu of some kind does any body have a picture or anything of the passenger footwell electronics cheers for any help
Re: [Mk2] [Turbo] passenger foot well
Post a picture up of what you have and I`ll check for you.![](./images/smilies/spacer.gif)
Lewis.![](./images/smilies/spacer.gif)
Lewis.
