Buying large exhaust gaskets? Nur-Spec
mattgt
Post by mattgt »
Was hoping to pick some up tomorrow to get my new exhaust on, anyone know of a nationwide place that stocks them? I need 2 x "two hole" and 1 "three hole"
80mm and 74mm
Or is it going to be a online jobbie?
1994 Astral Black Rev3 Turbo
HKS Induction > HKS SSQV > Greddy intercooler > Berk Downpipe > Blitz Nur-Spec> 2x Magic tree
ryan
Re: Buying large exhaust gaskets? Nur-Spec
Post by ryan »
I got these from my local motor factors. Think they were made by Bosal. They had a 2 and 3 bolt one on shelf and fitted my dep2 perfectly
mattgt
Post by mattgt »
Yeah was going to have a drive round and check out the local places tomorrow.
Did the Supra have a 3" exhaust ? :-k
ryan
Post by ryan »
mattgt wrote:Yeah was going to have a drive round and check out the local places tomorrow.
Hmm, havent a clue tbh
djpkins
Post by djpkins »
Be wary about the cheaper e-bay jobbies...I have had 2 from a guy on there...3" 3 hole mani gaskets...just blew straight out...within a day...both times....but deffo post up where you get yours from, cos I need to get another for my Dep2.
mattgt
Post by mattgt »
OK rang round every local place i can think of and no joy :(
Only place i have found them is Fensport which sell the genuine blitz items
Works out at £32 ish for all 3...
So.. what about exhaust putty/paste? yay or nay?
jon_st205
Post by jon_st205 »
No the pressure will just blow it out. Give your local tyre/kwikfit type place a shout.
dan1
Post by dan1 »
You might get away with re-using the old gaskets with some paste on :-k Think that two of them where in good nick so would be ok small bit broke off the one though but it might work with a good amount of paste. Could be worth a go.
Not sure if its cheaper from here http://www.blitz-uk.co.uk/Product-14.aspx
Could be possible to buy a sheet of the material and make some poss :-k
jon_st205
Post by jon_st205 »
Blitz UK = Fensport, FWIW.
mattgt
Post by mattgt »
jon_st205 wrote:No the pressure will just blow it out. Give your local tyre/kwikfit type place a shout.
Tryed them and nothing big enough
dan1 wrote:You might get away with re-using the old gaskets with some paste on :-k Think that two of them where in good nick so would be ok small bit broke off the one though but it might work with a good amount of paste. Could be worth a go.
Didnt think you sent the gaskets?? If you did it looks like im gonna have to sift through the bin to find them amongst the packing!
dan1
Post by dan1 »
#-o I taped them to the inside of the box lid with some bolts.
mattgt
Post by mattgt »
Indeed you did!! :lol:
Must have missed them while looking for the shiney bits lol Luckly i had kept the box, and yeah they should be reuseable.
Thanks again! :thumleft:
djpkins
Post by djpkins »
Tried old gaskets and paste...just blew out after a day...it's really hard to cut the mani gasket from a sheet of that gasket stuff without fking it.
Tmrw, I'm gonna just slap mine together without gaskets and use exhaust paste...remember to wash, rub down and wipe the surfaces, then wipe with a moist cloth before pasting up...I bought 3 new M10 stainless steel bolts/nuts for a snug fit and ease of lamping up really tight...essentially, as it was before i took it all apart to weld my flexi...no gasket and no blow.
phillips1981
Post by phillips1981 »
GTS chris sells them they're not sh#t paper ones either and its next day delivery. give him a bell. i ordered mine on a thursday saying i needed them for the weekend. came friday.
Give him a go
