Looks awesome did your engine builder make you down pipe or was it brought as part of a kit? be good to see a dyno graph when its finished 2.2 on a gt30 is going to spool up quick
Last edited by I am Spartacus on Tue Mar 01, 2011 7:38 pm, edited 1 time in total.
I am Spartacus wrote:Looks awesome did your engine builder make you down pipe?
Nope- Matt at Rogue put the downpipe together, I specifically wanted it to feed back into the exhaust system to try to keep the noise levels down to track friendly levels...he's done an excellent job on it
The plan is to run the engine in on my old PFC, then install the MoTeC and a few other toys before mapping for boost...can't wait
Ash looks good!! quick question.. What size pipe did you use on the wastegate? I have the same WG but im not too sure what size fits best, i know the inlet and outlet are different sizes..
I've been collecting parts for this build for over a year now, and I may have gotten a bit carried away
There are some more pics of the mani in my garage, it is a piece of art and made out of surprisingly thick gauge steel
