Over rev
Over rev
Thinking it's a slipping clutch but doesn't do it in every gear, only noticed it in 3rd and 4th when in the lower rev boundaries...say i put my foot down,the rev's go up faster than they should for the speed then drop back to how they should be...alot of noise and no action!!!
Anyone more clued up (which is anyone) got any other idea or similar feeling??
Re: Over rev
sounds like a clutch; this is a vid of mine when it was starting to go.
http://www.youtube.com/watch?v=7bwPWd5RjFs
0:18 from 2nd to 3rd ;P
Re: Over rev
That's the oneeeeeeeee!!! so ready for a new clutch then, I'll try and get a video aswell. Car sounds awesome by the way
Re: Over rev
sounds better now, that was right after I bought it, with stock exhaust.
It didn't seem that bad when I drove it around (slippage only at WOT), but when we took it apart it had almost no meat. So take it easy when driving around
Re: Over rev
i second taking it easy!
as many on here will tell you, very often the MR2 clutch will go from slight slippage to totally bu88ered suddenly and without warning.
Happened to me (on a motorway sliproad!) and has happened to plenty of others!
get it fixed as soon as you can before you get stranded somewhere! usual proces are around £300 all in from a decent trustworthy independant
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works. Or something falls off, in which case you've hit it too hard.
Re: Over rev
Then again MR2's always sound amazing [Smile]
Thanks for the advice guys coz I prob would drive it like I normally do. I'll take it easier for a while until I got it sorted! Am off on half term next week so I'll try and get it done then.
Last edited by Rubber Chicken on Thu Feb 17, 2011 12:19 am, edited 2 times in total.
Re: Over rev
Is it recommended to have anything else done at same time? Such as clutch lines or flywheel etc. Also the exedy clutch keeps appearing when I search, anyone got a suggestion on best clutch?
Re: Over rev
Do driveshaft seals and gearbox oil. Seals will get disturbed when doing the gearbox and will leak, theyre not expensive (15 ish each from mr T) and well worth doing. I got an oem clutch, but exedy is good I guess? I think for an NA it's not like you stress it anyway...
Re: Over rev
I know but I like a fancy name with it coz I'm stupid!
On that note...has anyone recommendations of clutches other than OEM...that aren't a stupid price either?
Re: Over rev
OEM clutch it is...looking at doing flywheel aswell though
Re: Over rev
Anyone know where the best place is to get a Fidanza leightweight flywheel?
Re: Over rev
I got a Fidanza flywheel for my tubby off Ebay from America. It was the cheapest I could find. Paid £236 including shipping and another £20 to customs on arrival. Best price I could find in the UK was around £300.
Re: Over rev
How long did it take to arrive?
Re: Over rev
About 2 weeks. It took longer to go through customs and be delivered by parcel force than it did to arrive in the UK from USA.
Re: Over rev
Is there a fidanza for NA 3sge? I thought the turbo one would be different?
Re: Over rev
Not sure. There's this one on Ebay which includes a compatibility checker on the listing page and if you select turbo as the Submodel it says it doesn't fit but if you select the Submodel as Base or All Submodels if says it will fit a NA but the engine size they show is 2.2L. A bit confusing and wouldn't like to say this one will definitely fit a NA!
http://cgi.ebay.com/ebaymotors/FIDANZA- ... ccessories
Re: Over rev
Fensport list one for the 3SGE but say it's for a rev2.
http://www.fensport.co.uk/Parts/Model_25/Category_3/762
Re: Over rev
Ordered this morning and should be here tomorrow
