Had a few overheating issues.
Just done a sniffer test and its come back with bad results!
What may of caused this? I mean I dont drive it like a total tit, always let it cool down etc.
Greddy Intercooler
Any ideas?
Just would be intrested to know.
willfinch36 wrote:Had a few overheating issues.tried thermostat, bleeding coolant etc.
Rogue wrote:willfinch36 wrote:Had a few overheating issues.tried thermostat, bleeding coolant etc.
This.![]()
The most likely scenario is that you have a separate fault that has caused the car to overheat which in turn has caused the headgasket failure.Be sure to pressure test the coolant system again once the headgasket issue has been resolved.
Lewis Jay wrote:Have you successfully cured overheating issues on many rev 3+4`s Patrick, by doing the headgasket or have these always turned into other problems e.g cracked blocks, co`s all the ones I have seen have never been headgaskets??
Lewis Jay wrote:Surley a pressure test would be the first thing you would do, not the headgasket then a pressure test..
.isnt a leak down test more likely to show block and or headgasket issues?
Rogue wrote:We use a pink dye that turns white when there's a crack.Don't ask me how it works, I suspect it uses voodoo!
willfinch36 wrote:It was a slight leak in the HG after all..
