[Mk2] [Turbo] What is stock oil pressure?
bobhatton
Post by bobhatton »
I am getting a dry sump pump designed and they are asking for the standard pressure at a RPM and temp.
Anyone know what it is please.
Bob
Slarty
Re: [Mk2] [Turbo] What is stock oil pressure?
Post by Slarty »
When warm (circa 85d C) at idle (850-900RPM), my oil pressure is 2 bar.
Not sure if that's any help or not?
bobhatton
Post by bobhatton »
Yes thats a start, thanks.
So 28 psi at 900 rpm, would you know what it is at say 6800?
Bob
Slarty
Post by Slarty »
At that RPM, I'd say the bypass valve would limit pressure? Deffinately on a cold(ish) engine and possibly on a warm engine?
I don't know off the top of my head, but my oil pressure gauge has a peak hold, so I'll have a look in a bit and see what the maximum pressure has been (which by my logic should be the bypass valve opening point?).
bobhatton
Post by bobhatton »
Yes it will be.
Thanks again.
Bob
Slarty
Post by Slarty »
5.7ish bar so about 85psi I'd guess?
dansREV2turbo
Post by dansREV2turbo »
my peak was 7 bar just before the limiter on my rev3 turbo, oil @ about 80-85 degrees c, idle at the same temp was 2.2bar
Slarty
Post by Slarty »
dansREV2turbo wrote:my peak was 7 bar just before the limiter on my rev3 turbo, oil @ about 80-85 degrees c, idle at the same temp was 2.2bar
Where are you taking your pressure reading from dan, out of interest? Mine is from the OE location on the cylinder head.
I don't think the idle pressure is as important as it's conditional on too many variables (oil grade, age of oil, engine milage and wear etc).
dansREV2turbo
measurement was taken from an adaptor between oil filter/block for my greddy oil cooler :thumleft:
GTS GAV
Post by GTS GAV »
Im reading near on the same as dans readings, my readings are taken from the oem head position. Built engine
Dead on 3bar at idle, 7bar at 6,000rpm+, oil temp around 78/85 Deg
stock isnt that soup or something.....?
tic tac 500bhp build thread
http://www.imoc.co.uk/forums/viewtopic. ... 57#1182357
Shmed
Post by Shmed »
Where is the 'best' place to take oil pressure readings from?
January 2014
May 2015
Still in the garage...
greeny
Post by greeny »
Shmed wrote:Where is the 'best' place to take oil pressure readings from?
The pressure "should" be the same wherever you take the reading from.
Id take it from the same place as the oem sensor, its the furthest away.
Shmed
Post by Shmed »
Cheers, thats what I decided on. Ordered a splurged so I can fit my gauge sensor as well as the stock one. :thumleft:
January 2014
May 2015
