I am getting a dry sump pump designed and they are asking for the standard pressure at a RPM and temp.
Anyone know what it is please.
Bob
[Mk2] [Turbo] What is stock oil pressure?
Re: [Mk2] [Turbo] What is stock oil pressure?
When warm (circa 85d C) at idle (850-900RPM), my oil pressure is 2 bar.
Not sure if that's any help or not?
Yes thats a start, thanks.
So 28 psi at 900 rpm, would you know what it is at say 6800?
Bob
Bob
At that RPM, I'd say the bypass valve would limit pressure? Deffinately on a cold(ish) engine and possibly on a warm engine?
I don't know off the top of my head, but my oil pressure gauge has a peak hold, so I'll have a look in a bit and see what the maximum pressure has been (which by my logic should be the bypass valve opening point?).
Yes it will be.
Thanks again.
Bob
Thanks again.
Bob
5.7ish bar so about 85psi I'd guess?
my peak was 7 bar just before the limiter on my rev3 turbo, oil @ about 80-85 degrees c, idle at the same temp was 2.2bar
dansREV2turbo wrote:my peak was 7 bar just before the limiter on my rev3 turbo, oil @ about 80-85 degrees c, idle at the same temp was 2.2bar
Where are you taking your pressure reading from dan, out of interest? Mine is from the OE location on the cylinder head.
I don't think the idle pressure is as important as it's conditional on too many variables (oil grade, age of oil, engine milage and wear etc).
measurement was taken from an adaptor between oil filter/block for my greddy oil cooler
Im reading near on the same as dans readings, my readings are taken from the oem head position. Built engine
Dead on 3bar at idle, 7bar at 6,000rpm+, oil temp around 78/85 Deg
stock isnt that soup or something.....?
tic tac 500bhp build thread
http://www.imoc.co.uk/forums/viewtopic. ... 57#1182357
Where is the 'best' place to take oil pressure readings from?
January 2014
May 2015
Still in the garage...
May 2015
Shmed wrote:Where is the 'best' place to take oil pressure readings from?
The pressure "should" be the same wherever you take the reading from.
Id take it from the same place as the oem sensor, its the furthest away.
Cheers, thats what I decided on. Ordered a splurged so I can fit my gauge sensor as well as the stock one.
January 2014
May 2015
May 2015
