http://cgi.ebay.co.uk/FIAT-CINQUECENTO- ... 415245231d
Also, on this thread here:
http://www.imoc.co.uk/forums/viewtopic. ... er&start=0
he has this list of parts.
Parts bought so far:
From Toyota
1 x Bottle of ForLife- T08889-80002
2 x Bolts to bolt down CC core
2 x Long Throttle Body Bolts w/washer
4 x Throttle Sock Bolts
1 x Throttle Sock
1 x Accel.
1 x Engine Hoist Hook
2 x CC Pump Bolt
4 x Foglight Bolts
1 x Throttle Body Support
1 x CC Expansion Tank
From eBay
1 x Fiat Cinquicento Radiator
1 x Fiat Cinquicento Fan Switch
Several jubilee clips, I'll inventory these as I go
From Forge Motorsport:
2 x 32mm
2 x 19mm alloy hose joiners
more jubilee clips that I forgot about when I ordered the eBay lot
From B&Q:
2 x 1m lengths of steel bars.
2 x M6x60mm bolts
2 x Washers to pad out the above bolts
4 x 6mmx20mm self-tapping screws to attach rad to brackets
From Motorserv:
10m of 19mm ID coolant hose
Yet more jubilee clips
I know the thread linked to is pretty comprehensive, but I wanted to check in case anyone had refined the installation since it was first posted, using any different parts or leaving anything out.
Big thanks in advance for any help offered
