Hi,
Recently the front right bulb went and the indicators were flashing quicker than usual, as they do. Then shortly after the stick no longer relays the message to the indicators!
The indicators all work when i put the hazards on and when locking and unlocking with the key fob.
The fuse is ok, but what else could i do to solve this problem?
TIA
[Mk2] [Turbo] Indicator stick not working - Help?!?
Re: [Mk2] [Turbo] Indicator stick not working - Help?!?
contact on the indicator ok ?
SFLee wrote:contact on the indicator ok ?
Not sure on that. Where would i look for that?
you may need the bgb see the wiring diagram and test the wire using a volt meter
