anyone done this.
tips needed
bonnet mods
Re: bonnet mods
that looks lovely
Re: bonnet mods
What colour is that? it looks great
Re: bonnet mods
mulaz wrote:What colour is that? it looks great
Looks like Medium Red Pearl (3H4)
The mod itself has been done before, MartG has one, Paul woods has done a few i think. That one does look neat though.
Re: bonnet mods
Cut & paste from my thread elsewhere:
Off came the bonnet
Marked out
And cut
Now for the other side
Welded
OK, not the biggest bonnet vent on the planet, but hopefully will aid cooling and reduce front end lift a little
Filled the sides ( styrene sheet and Isopon )
While that was setting, I removed the rad fans, and refitted my modified radiator clamps they now hold the rad in the same position as in a Mk1a. This should allow a little more upward airflow.
Isopon set time for the expanding foam filler
Off came the bonnet
Marked out
And cut
Welded
Re: bonnet mods
nice
thank you.
now where is my slitting disc.
thank you.
Re: bonnet mods
That looks great!
Re: bonnet mods
MartG, the only man in the world with an mr2 bonnet shape sprayed on to his garden as a unique grass feature. LOL
I like the idea.
I also like the mod and the good simple write up.
Nice one!
I like the idea.
Nice one!
Re: bonnet mods
That's not a bonnet vent....
THIS is a bonnet vent
Re: bonnet mods
not bad.
shame the frunk is us though.
Re: bonnet mods
Frunk still perfectly useable, the vent dives into the front panel which has been chopped out to allow the airflow, so it has lost very little frunk space.
Re: bonnet mods
kool.
gonna make me one then.
Re: bonnet mods
humpf.
i used to like you.
i used to like you.
Re: bonnet mods
We are actually going to get this one moulded up, so you will be able to buy a FG insert that goes where the centre section of the bonnet is, making it relatively easier to DIY
Re: bonnet mods
come on then, that sounds brill.
like you again now.
like you again now.
Re: bonnet mods
If you're interested in Mk1 aerodynamics, have a read of this http://www.mr2oc.com/showthread.php?p=2 ... ost2630951
The CFD plot on the first page of that thread clearly shows the low pressure area on the bonnet that a bonnet vent will remove, thus reducing front end lift at speed.
Re: bonnet mods
stupid question paul - what stops the water going into the radiator fans? or is that not an issue?
Re: bonnet mods
Not an issue, the fans are exposed to the elements on all mk1s, plus the water running off my vent misses the fans anyway.
Re: bonnet mods
wow that was one interesting read about airflow.
the rear spoiler is next to useless
