[Mk2] [Turbo] catalytic converter and mot
my car is 01/11/1994 does this mean it needs a cat.the garage says it has failed the emissions test due to there being no cat. if so how do i go about getting one with a TD06 turbo kit on it with an external wastegate.As this flange as you know is a 3 stud type....??HELP well anoyed as ive spent a fortune getting all my exhaust custom made lol.
Re: [Mk2] [Turbo] catalytic converter and mot
as far as i remeber
import is 95 rather then 94
because 3sgte engine does not exsit in uk (even updated edition still not there)
check the chart above
and
http://www.motuk.co.uk/images/7.3page9.pdf
is latest version which clearly state the correct year
unless you fail because it is higher then the non cat test
you can ask him which model of car did he compare the reading to
you may found it point to a 3sge
and
