Front mount intercooler?
Hi does anyone know of a front mounted intercooler set up being used? Was thinking of running one with a NX exPress nterCooler system and big turbo? Was thinking this would be good on a drag strip?
Re: Front mount intercooler?
phoenix's power did a 2 with a front mount in it, the is pipes went straigh through where the passenger would sit.
can't find any pics atm.![](./images/smilies/spacer.gif)
Its not a very good idea.
The pipework is too long for air to flow through without adding massively to lag.
On the dragstrip i suppose it might be better, especially if you ran the pipework straight through the cabin like Phoenix Power did, but it would be awful on the street.![](./images/smilies/spacer.gif)
Front mount chargecooler rad is fine though, because the
air
only flows a short way, but the liquid that cools it is steadily pumped from the c/c core up to a rad at the front of the car.![](./images/smilies/spacer.gif)
If you just want a big I/C, just go bootmount.![](./images/smilies/spacer.gif)
Heres a links for the pheonix power mr2 with intercooler at the front they are mounted where the spare wheel once lay.
Surely one of the best mr2s ever
http://s3.invisionfree.com/homiehookups ... topic=2189
wadeski wrote:Its not a very good idea.The pipework is too long for air to flow through without adding massively to lag.
Front mount chargecooler rad is fine though, because theair
![Image](http://ll.speedhunters.com/u/f/eagames/NFS/speedhunters.com/Images/Linhbergh2010/July2010/Car%20Features/PinkS14/IMG_4746.jpg)
http://www.chevyhiperformance.com/techa ... index.html
Rob B wrote:Heres a links for the pheonix power mr2 with intercooler at the front they are mounted where the spare wheel once lay..
Oh I remember that beast from my Max Power days
![Anxious 8-[](./images/smilies/eusa_shifty.gif)
