He's just bought it and its started smoking.
It smokes when the car is up to temperature and when you park up and let the car run for a while on idle after about 30 seconds white smoke starts to pour from the exhaust, a couple of blips from the throttle clears it again.
I completed a compression test for him and it showed 12 bar across all cylinders when dry.
Does anyone know what it could be?
My thinking is rings, head gasket or valve stem oil seals? Am I heading in the right direction?
Cheers,
Adam
